1965 Plymouth Satellite - Will not stay running
Where is the issue?
  • Carb
    Votes: 0 0.0%
  • Ignition
    Votes: 0 0.0%
  • Timing
    Votes: 0 0.0%
  • Total voters
    3
I know this post is old but I will say I am definitely going to to bookmark this for reference. You did an awesome job checking EVERYTHING. I have a similar issue and I too feel like I may have some weak spark. I did some initial checks as you have and didn't notice anything crazy out of whack. I ended up replacing most of the ignition just because I have no idea how old the components were and I really didn't mind having buying new stuff. I used either blue streak or NOS parts. I still feel like the spark looks a little weak and I too have trouble initially starting the car without giving it a shot of starting fluid. Once it clears its throat and warms up it actually revs pretty clean. I quickly installed a new condenser but really need to set the gap correctly with a fueler gauge. Hopefully that's my problem. Again good stuff and thanks for all the detail.
Once you reset point gap, reset timing. Changing timing will not affect point gap (dwell), but adjusting dwell (point gap) will affect timing.
