I am very impressed with the work you are doing, just stunning. Had no idea of a weld thru primer, thank for that tip.Some surface rust and dirt in the rails. I extended some wire brushes and cleaned them up nice. New gas tank brace welded in. The rails and edges were por15’ed and hit with some weld-thru primer to get them ready for the AMD 1 piece trunk pan.
View attachment 1054994 View attachment 1054995 View attachment 1054996 View attachment 1054997 View attachment 1054998
It's been awhile but I think during final assembly/welding you fold those little tabs up and weld (supposed to spot weld) them to the bottom quarter/trunnk extension seam.
Getting that whole corner/rear valance/quarter panel/trunk drop off deal all fitting perfect is pretty finicky. I ended up having to cut the quarters at that point and add a pie cut in to make it perfect on my son's 68. Really take your time with it.
Can you talk about your experience with POR-15 weld-thru primer and how you use it? Do paint all surfaces, just the backside, clean just the weld area? So many questions. How long have you been using it and any long term observations. ThanksSome surface rust and dirt in the rails. I extended some wire brushes and cleaned them up nice. New gas tank brace welded in. The rails and edges were por15’ed and hit with some weld-thru primer to get them ready for the AMD 1 piece trunk pan.
Did you have to replace the shock mount cross member or is it por-15 painted? Are the edges only coated with the weld thru primer? I love watching you work through the process, you certainly are a master of your trade. Thank you for sharing your skills and the process.Some surface rust and dirt in the rails. I extended some wire brushes and cleaned them up nice. New gas tank brace welded in. The rails and edges were por15’ed and hit with some weld-thru primer to get them ready for the AMD 1 piece trunk pan.
This can be repaired without any slicing, by bending the rear cross member that is behind the valance. The corners are welded to the crossmember and by bending the ends of the crossmember forward, it pulls the corner in to close the gap. This is the way the factory did it. Most people don't realize this and cut and weld.Those rear corners are a part that i am concerned about on my build as well. How do you decide that the quarter needs to be sliced and moved back instead of the corner/rear valence moving toward the quarter?
This can be repaired without any slicing, by bending the rear cross member that is behind the valance. The corner is welded to the valance and by bending the ends of the valance forward, it pulls the corner in to close the gap. This is the way the factory did it. Most people don't realize this and cut and weld.
