1969 Dodge Charger RT Restoration
Under body coating is complete as well as inside the quarters, trunk, and doors. The 3M 08864 is very thick and looks much more like original than anything I have used before. It required about 10 bottles. I used the $15 Schutz gun from Amazon and was very happy with it.
20200823_160002.jpg 20200823_121105.jpg 20200823_121128.jpg 20200823_160058.jpg 20200826_190744.jpg
The doors, tail panel, and behind the headlights have now been blacked out. The back looks so much better.
20200902_183443.jpg 20200907_192643.jpg 20200908_130445.jpg 20200908_132456.jpg
The suspension and engine have all been taken apart as well. Some of those original bushings were in much worse shape than I thought. Many of them were a bear to get out! Does that drive shaft look original? They way one end was welded made me unsure. How about the cam, there are some numbers on there?
The engine, except for the cam all looked better than expected. From my micrometer it looks like it may have never been bored out, but we will see what the machine shop says. If anyone knows of a good MOPAR engine shop in or near Atlanta, please let me know!
20200912_151205.jpg 20200912_151221.jpg 20200914_172404.jpg 20200917_183121.jpg 20200917_183124.jpg
I think I got lucky, every date code I have checked seems to be right to be original.
20200926_145923.jpg 20200926_155327.jpg 20200926_145954.jpg 20200926_123627.jpg
In November and January I restored suspension and engine parts, and even got a few installed. Most suspension parts were powder coated.
Used Caswell Plating's black oxide kit for most of the hardware, it works very well. Some of the parts were then also painted for extra protection or to get a closer color to original.
20201011_180849.jpg 20201011_181943.jpg 20201014_132135.jpg 20201023_140258.jpg 20201023_140310.jpg 20201024_132315.jpg 20201024_102002.jpg
The rear end was changed not too many miles ago (but 12 years), but has had a slight whine since. The play was on the high end so I tightened it slightly to hopefully improve that. They are Motive Gear I believe.
The Derrick Weaver rotisserie has also been sold as the rear suspension is back on. It made stripping the underbody coating and doing everything underneath so much easier.
I am trying to go back mostly to original, but am making 2 upgrades. A Leeds front and rear disk brake kit and Holley Sniper EFI. For the brakes I am not using power brakes as I like the clean engine compartment look and liked the brake pedal feel of the original 4 drums. For EFI I am using an EFI tank as I liked the baffles. Not cheap, but they installed nice.
For the gas tank I connected to the two new vents and am going to use the one on the original filler tube that goes into the trunk floor frame rail. I made sure it was clear and hope this is enough. I didn't want the shut off vent valve installed in the C pillar as some others have done. Any thoughts on this and if this will be enough?
20201102_165645.jpg 20201113_161607.jpg 20201114_122703.jpg 20201114_123817.jpg 20201114_133222.jpg 20201122_163514.jpg 20201126_174104.jpg
In January I am finishing the restoration of engine and suspension parts and getting some of them installed. Parking brakes are working and most of the brake lines are installed. All of them are stainless steel from Inline Tube. They all installed very nicely. Was able to save the vacuum canister under the battery tray with one spot of JB Weld. It was fun and cheap rebuilding the power steering pump. Most of my engine components look original which is surprising for over a dozen different owners.
It was so dusty inside and out I had to give it its first wash inside and out. Strange washing half a car.
20210115_170505.jpg 20210115_170500.jpg 20210114_180610.jpg 20210114_181726.jpg 20210114_175518.jpg 20210109_105043.jpg 20201231_152829.jpg 20201219_151912.jpg 20201209_173702.jpg
Now I am all caught up.
Anyone know if these are Mopar wheels? They are 14 inch and have been on my car for 18 years.
View attachment 993871 View attachment 993872 View attachment 993873 View attachment 993874 View attachment 993875
So you coated the inside of the quarter panels with this and then painted over the coating blue? I cant tell from the pic. It just looks like a blue inner quarter to me?
Or this pic is before you sprayed the undercoating? If so can you paint over the undercoating? Do you have a pic showing what it looks like after spraying?
The entire trunk was painted, then taped off weeks/months later. The under body coating was spayed back to just before the marker light and as far forward as I could get. The picture where the the trunk is taped off is just before the under body coating was sprayed.
The heater box was a good weekend project. I liked the rebuild kit from Detroit Muscle Technologies. I have bought many of my soft parts from them. It came apart and back together very nicely. It definitely needed it! The motor I bought 10 years ago did not have the vent hole in the right spot so the vent was extended.
20210123_131857.jpg 20210123_131935.jpg 20210123_135210.jpg 20210123_135201.jpg 20210124_183718.jpg20210130_150527.jpg
The engine came back from the machine shop as well. I used Ewing Automotive Machine Service in Snellville, GA. They are reasonable priced and everyone I talked to recommended them. It turned out to be in very good shape. It was not bored out previously but was this time it was to 30 over. Most components were still good and were reused. The only upgrade was a mild cam.
The 78 Bronco and kayak trailer worked great for drop off and pickup. Makes sense to use a 429 to get a 440.
There were a few problem areas. First, I pre-painted more than I needed too. I wanted to paint the valley pan and the bottom of the intake (for rust prevention), but I should not have pre-painted so far out and the hold down bars. Second, I taped off to much around the exhaust manifold bolts. I later saw people taping closer to the bolt holes. I will probably have to touch up some gray spots. And third, the dip stick tube is a pain. They are way too tight and I broke the first and scratched the second. With the second I even grinded the end and should have done more. I still couldn't get it in the last 1/4 inch.
I never did find original looking valve cover bolts, anyone know where to get some? Detailed pics of what was in the passenger side valve cover clips would be great as well!
20210208_142730.jpg 20210208_151938.jpg 20210208_174742.jpg 20210214_092928.jpg 20210214_101714.jpg 20210221_112534.jpg 20210221_151241.jpg 20210221_160800.jpg 20210225_174451.jpg 20210225_182239.jpg
The engine has been accessorized and installed.
20210227_214807.jpg 20210228_155018.jpg 20210228_155031.jpg 20210228_161616.jpg 20210228_185203.jpg
Also received the Accurate Exhaust full system. Very nice quality and easy to install at home with one person. Front suspension is complete as well.
20210314_151236.jpg 20210313_141953.jpg 20210313_163216.jpg 20210324_191536.jpg 20210320_171115.jpg 20210324_192303.jpg
We also have wheels and tires. The rear wheels just barely hit the disc brake calipers, so I needed to run 1/4" wheel spacers. This meant I needed longer wheel studs so I switch last last wheel from left and threads to right to match the others. The front was changed with the disc brake swap. So far I am liking the 245's in the front and 275's in the rear.
20210326_194857.jpg 20210326_205725.jpg 20210326_224826.jpg 20210328_101049.jpg 20210326_221517.jpg
I'd install some doors on that thing or it'll be cold as hell on spring and fall days like a Jeep! Haha just playing man the car looks awesome keep it up! Nothing like a 2nd gen Charger and magnum 500 wheels!
Ugh, last week I spent an hour and half catching up on the current status. The site let me add a half dozen posts with lots of pictures. A couple hours later the this site went down for a day. When it came back all the recent posts were wiped out.
I have done a lot since April. Suspension, exhaust, brakes, body panels, engine electrical, and grill are all done. I am very happy with the Accurate Exhaust B body kit and Leeds brake kits I bought. Both were very complete, look great, and went in very easily.
20210314_151236.jpg 20210324_191619.jpg 20210410_184520.jpg 20210410_184538.jpg 20210418_163907.jpg
