Game on!!!!
3400 if I remember correctly. John said it would drive around town like a sweetheart but ehen you get on it, it will flash to 3400 snd roast the tires off lol.Sweet!.. What's the stall rpm?
Looking good! Takes a little time and patience by your self but doable. Looking good. Is your oil sending unit for the warning light or gauge. I know there is a different one for each.
The dash light. The sender for the gauge is larger.
It isn't a bad one man job. I gotta get under it and mess with the trans alignment to get the pin to drop into the pocket. Otherwise it is right there. After it is fully bolted up, I need to figure out how the best way to get the starter in.
i hate to rain on your parade, and do as you will with it, but ive seen it enough to be concerned and just want you to be aware of it, especially given how high that stall converter is, itll load down right through the crank pretty tough when it rips free. ive seen a lot of badluck coming from using an impact to trust the tightness on flex plate bolts. its fine on a little no torque small block but with that much torque in a heavy car you really outta use a torque wrench on the flex plate. theres two reasons why, thread and bolts,. number 1 is most cranks are just cast iron, threads in them are fairly questionable to begin with. off hand i can think of 4 different times ive personally seen "over tightened" via impact wrench flexplate bolts rip out under hard loading. granted it was at the strip three times and once on the road. but the common denominator through discussion in the pits was "they shouldve been tight enough i used the impact gun on em" only to see at closer inspection the bolts didnt come free, they ripped out leaving 6 smooth holes. they only need to be tightened to 55 ft/lbs, thats hardly anything. wheel lug nuts need more then that. impact guns are WAY more capable then that. a thread formed in a soft metal thats being pulled on by a couple hundred ftlbs is waiting to rip out. then you throw 3400rpm of 450ish foot of torque multiplied with a 3700lbs car twisting and yanking at it. if the flexplate rips off youll either have to band aid it with helicoils or rebuild the motor with a new crank
the number 2 reason is, without reading all the way back into when you built the motor i cant remember if you have a cast or a forged crank. say you do have a forged crank, they are still only 7/16ths bolts holding them on, designed for that 55ft lbs. even top of the line arp forged bolts, preloading them that much with the impact gun is a bad idea. even grade 8 life depended on it 7/16th bolts in a a plane or a tank or something are are rated at a maximum recommended of 58ft lbs. at least you have an automatic so if the heads pop off they dont mangle a clutch.
just my 2 cents. all that work and money and the weak link could be in those 6 little bolts. to me, a swinging motor is always worth the hassle to properly torque something.
well at least you didnt hammer them in till the gun stopped spinning. in that case they'll probably be fine. .I appreciate the input. The crank is forged. I did not rattle the bolts on full force. Low setting on the gun, until contact and one or two quick bumps. I'm not gojng to say they are exact at 55ft/lbs but they are not excessive and should be pretty close.
