Here is the 484... i know it's just a video.. but just to get an idea of idle quality..
And you don't want a .590 He was being sarcastic...thing sounds amazing though
That .484 sounds sweet! What do you have your timing and idle set to?
sorry, that's not my car i just found a video.. i sold my car a long time ago..That .484 sounds sweet! What do you have your timing and idle set to?
Good to knowMancini is selling their Purple cams in these flavors.
B/RB 361-440, 474/280 Hyd Flat Tappet
B/RB 361-440, 284/484 Hyd Flat Tappet
B/RB 361-440, 292/509 Hyd Flat Tappet
B/RB 361-440, 312/590 Mechanical Tappet
The engine builder (drag racer) that built mine put in a moderate Purple Shaft Cam (it was in the 80's and I can't remember the #'s now) and new pistons w/ 10:1 compression, block was bored .20 over stock. Idles fine, sounds tough, bad to the bone. He tried to keep it street-able, but just barely.Hello, I have a 383 Mopar that I am completely rebuilding, we are planning to put in a Purple Cam which should be a step higher than the stock one. If we do this would we have to change the pistons or would stock work better? I did some research and I believe the compression ratio for a 383 Mopar is 9.5.1, not 100% sure. I also read that it's recommended to keep stock pistons because otherwise, it'll run crappy unless running a high idle with a purple cam. If someone can let me know whether to keep stock pistons or get a different kind? Thank you
^^^Totally agree. Put that cam in my 383 and required a 3000 stall converter. It really came to life when I changed out the 8 3/4 pumpkin with 3.91 gears.I have a 484 in my 440 with a 5spd TKO and 4.10 Dana.
I would not put the 484 in a street 383 personally without some converter and gear.
When you say more than stock cam do you mean the 2bbl cam or the roadrunner cam?
^^^^ agreed ^^^^^If you got nothing else, but "stock" intake, exhaust, etc. you'll be better off with the 280/474. None... of the others listed.
