2 engines & 1 car what a dilema...LOL..., It's great to have choices... I will 1st state, There's nothing wrong with the 383ci BB Low Deck Wedge {or 388ci @ 0.030" over}, especially for street use & regular daily type driving, with the occasional stop light to stop light blasts, easily 400+ hp with basic performance mods & correctly done builds, probably a little more fuel efficient, than a 440ci they are also slightly, lighter, narrower & shorter, you can have more hood & header/exhaust clearances, 383ci/3.375" stroke vs 440ci/3.75" stroke is the biggest differences, stroke is torque, torque make a heavy car move more effectively/efficiently, bore of 383ci/4.25" std. to 440ci/4.32" std. bores, only 0.070" difference, both 383/440 use basically the same cylinder heads, the identical cylinder heads on the 383ci are more effective/efficient than on the 440ci in stock form, more flow per/ci, for the 440ci they should be worked a little more, the 383ci & 440ci basically used the same camshafts, so the effective/efficiency, was better on the 383ci, also the lighter engine, will have slightly less tire, shock, brake, wear & will aid to slightly better performance/handling & weight distribution also... but if you already have a 440ci installed in the car & your not trying to make a 100% OEM #'s matching 100pt correct restoration, there is no replacement for displacement... For not much money, the best of both worlds, especially if the car is an original 383 car, would be a lighter 383 low deck block, good properly matched components & gaskets, with a properly machined 440 crankshaft & custom 0-deck pistons, the proper camshaft & cylinder heads, induction & exhaust for your intended usage, @ 431ci @ 0.030"over bore 4.280"x 3.750" stroke, 440 power in a 383 package, not really a race engine, just a great street strip engine combo, NOTE the 383 blocks are weaker in the main webs, than the more desirable 400 low deck B-blocks, but comparable with the 440 main webbing, good to about 550hp with out a girdle or special modifications.... Good luck in what ever you decide to do... Properly done/worked, Cylinder Heads are everything, for making great usable HP/TQ on any Mopar BB wedge build 361-383-400-413-426-440... The 383 seems to be the bastard little brother of the BB Mopar Wedge world, much like the 318 in the Mopar SB Wedge world, they both are viable in their own ways, sometimes you just need to think outside the box...
