Orig69
- 10:27 AM
- May 16, 2021
- Toronto Ontario Canada
If you want to know what it is, then just raise the timing to 20-22 degrees and let the engine get to operating temperature and then try to see if the hesitation is gone or almost gone.I was going to gradually increase the timing to around 20 degrees or whatever it could take and not ping and start without too much load on the starter.
Then you can put the ignition timing back to where it was, if you want to.
That does look like a 4 speed carb.
