Geoff 2
When you run MVA or PVA, the carb can run lean, especially a production carb. It is a 'quirk' of VA. The extra timing from VA makes the engine more efficient & it requires less fuel to produce the same rpm. Using MVA as an example is easier to understand the concept: idle mixture comes from the idle port AND the partly exposed transfer slot; idle rpm increases when plugged into MVA. When idle rpm is reset to the original speed, less T slot is available for idle fuel & the mixture is leaner. The fix is often as simple as adjusting the mixture screws but sometimes the IFR needs to be enlarged slightly.
I haven't read the whole thread, but a bigger cam &/or lower CR require more idle fuel.
Congrats on using a great carb.
New dist. Simplest route is to buy the Chrys elec ign kit. Points belong in a model T....
