66Satellite47
The EDE RPM's are a very nice head. They will cover a wide range of performance applications. I'd still have the guide clearance and valve job checked out by a performance oriented machinist.
I agree.I would shoot for down closer to an 8:1 DCR by entertaining the slightly larger XE268H Cam and 60* ABDC closing with the Eddy 60929 Heads and 8519PT-1 (10.2 CC) Head Gaskets at 9.84:1 static.
We have experienced no complaints using a stock Torque Convertor behind 268 similarly equipped 440's.
I'm really confused about the term quench.Made 810 hp and 730 Ft/Lbs on the Dyno with a 540 Wedge one day....
then
we changed from a .039" Head gasket to a .080" Cometic right there on the Dyno...
NO other changes other than a CR drop and BIG increase in quench, then we re-assembled....
and
watched it kick 849 HP with 750 Ft/Lbs !
Morale of the story....
don't go chasing your tail that "quench" absolutely MUST BE a certain number or that tighter is ALWAYS better ?
Depends on the Engine...
Different Bore Sizes like different Quench distances depending upon things like the Intake/Exhaust Flow Ratio....Cam Scavenging characteristics... Valves opening "on center" of the Cylinder(Hemi's and SBM) Vrs the "Backside" of the Cylinder(SBC and BBM).... and on and on....
Now I just shoot for .045"-.055" on a BBM and call it a day !
then
and
