brywatz
Ignition is new. Converted it to mopar electronic after it happened. New msd coil. Not a rhythmic miss, pretty erratic. It runs the same if I leave the choke closed. I didn't check the air gap, but its running the exact same as it was with the old distributor so i dont think its that. Timing is on, can't find any vacuum leaks. I still think its a fuel issue, but thought it was the pump. Gonna change carb later today. I don't know anything about the fuel pump rod, except that I had to lift it to get the pump in, and it was a pain in the ***. How do you check it? Gonna check the regulator too. Thanks again
