Bicylindrico
The 70's were all about one thing, clean up emissions with old polluting large displacement engines. They would essentially run late timing at higher engine speeds to help clean/heat up exhaust emissions. This all at the sacrifice of engine performance.How was it hooked up by the factory? Not offended, but explain?
The easy way to think about it is lean fuel mixtures need more time to completely burn=idle and cruising. Rich fuel mixtures need less time=load. All these guys running no vacuum advance would be amazed how faster their engines would idle if the timing was advanced properly which would lead them to have to adjust their throttle plates and idle mixtures screws to bring the idle speed back down. That is what timing advance does for an engine.
