BSB67
O.K. guys thanks for all the advise, it has been an overload of information but helpful.
I have my timing set as of this past Saturday at 12 degrees initial, at 2500-2800 rpm I am at 33 with no vacuum hooked up and idel at between 90-1000 rpm. I reconnected the vacuum and I ran the car and got good take off with no bog at WOT and very little ping at all on pump gas. 104 booster took care of that. Ran great but did seem a little slower. Reset the the timing to 14 base (i had marked the disributor because it was set like this initially), did not read the upper this time, pinging at the slightest acceleration under load did just like before. disconnected advance and it was fine with more power. Tried moving timing to 18 but the car hates to idle there very rough weather vacuum is connected or not.
I am sure there is a way to get this motor to perform better but for now I can drive it and if I set the timing to 14 base without vacuum I can play a little harder. Here in Atlanta the heat will determine what happens next but i will have to wait till its spring.
I used to have a very heavy WOT bog, and it made pulling in traffic a nightmare but now it seems to be acting like a normal car. then the timing was at 10 initial, so I am slowly creeping up on the correct set point. I still would like to try the firecore distributor for adjustability. but are there any other tweaks to get a little more out of it without the ping? or would that take a new dizzy or timing curve adjustment to my present set up.
thanks again everyone, you had me in the garage playing, and learning new things and staying away from the honey do lists. Best Weekend in years.
If you are at slight ping under part throttle load, or WOT, try a cooler spark plug, cooler thermostat, and blocking the intake heat cross over. AF ratio adjustment can help too if you are on the lean side.
