Hahaha!!! This gets a lot of people going alright. I have one car running off manifold, another off ported. Both run very well.
I think what happens with this debate comes down to how much vacuum your engine makes. Good vacuum you use the ported. Low vacuum (with the bigger cams) you might find that the manifold will work better because you don't get the reaction from the ported.
I tried both with my 440 build and the ported works the best. It doesn't like manifold at all.
You really have to start with the basics.
1.)Verify you timing on the dampner as being true TDC. (Use a piston stop to verify)
2.)Unhook the vacuum advance and plug the carb port.
3.)Timing light hooked up, check the timing mark at idle on a warmed up engine.
4.)Get a base line at idle while adjusting the distributor. (Say 15* for an example)
5.)Having a tach hooked up where you can read it while under the hood, rev the engine slowly while watching the timing mark. When it stops moving, check what RPM the tach is reading and note where the mark is on the balancer. (Say 34* @ 2000 RPM)
This is the total mechanical advance that your distributor has. (34* - 15* = 19*) 19* is the distributors mechanical advance.
6.)Now hook up your vacuum advance and rev the engine slowly. Watch the timing mark advance until it stops moving. It probably won't stop until it's up around 50*. Take note of the RPM and where the mark stopped.
This is how you find what your timing is doing. If it's getting too much mechanical timing or not enough, the the counterweight stops will need adjustment. If the mechanical timing comes in too soon or too late the advancement springs in the distributor will need changed to get what you need. If the vacuum advance comes in too soon or is off the timing scale, it will need adjusting if its possible with the vacuum advance can that's on the distributor.
