Chrysler Corp. never made a single "Hi-Po" engine with any after market/other manufactuers intake except the Edelbrock 6 pak intake manifold. The LD4B is an over the copunter aftermarket part from Edelbrock. You could purchase it from Direct Connection (MoPar Performance) or through a speed shop.
The LD4B is designed as a stock replacement type of intake with a squar flange. Designed for the 273/318 engines, the port window size is small for the 340/460.
The Edelbrock 600 cfm carb issmaller than a stock AFB/AVS and the TQ. While it may be sized well for general duties, it is small.
The stock as delievered 360 4bbl. was around 255 HP if it was a HP version, and not knowing if you have that HP version, I'll just assume it could be and go on from there. Yes, the 360 cam with the 340 cam shaft, but, suffered a low compresion, (Sometimes less than 8-1) small valve size (1.88 Intake) and emmision equipment to bog it down on power. (Not all of the smog equipment was power robbing.)
Since the HI PO engines were rated ataround that 255 HP area, the loss of the iron 4bbl and TQ carb is hurting it's performance. The Edel. intake and carb are less of a performer than the OE equipment delivered on the engine. I was take an educated guess and say that this engine would make 260 Max HP.
To bolt on a few parts for performance, step up to ethier the LD340 or RPM and a 750 carb, add a 340 or your cam of choice. Add headers and a 2-1/2 exhaust. Grab a performance distributor if your current unit does not have a vaccum advance on it. (AKA Lean burn distributor does not have a vaccum advance on it.)
Milling the heads down for added compresion is a big help. Look to gain 1 point or so in this area. The max you want to go is 9.5-1 with an iron head and pump gas. Installing a 2.02 intake valve is generaly not needed. Any porting done shoul;d consider the level of performance being sought. If only a little performance is desired, AKA daliy driver or street machine, just bowl port the heads.
Power without bowl porting can be expected in the 350 hp area
Bowl porting included can added approx. another 25 - 30 HP on this mellow mill.
