Picture looks like it was takin' after cocktails. Looked like you were park on a hill, telephone pole gave it away.Took her out today for a quick adult beverage….or two. 70 degree day in South Mississippi!
THANKS!!!Years ago, I bought a set for a1964 Polara 500 convertible I was restoring. They were reproduced in fiberglass and came with flat aluminum base plate and oval filters. I think the guy was in Arizona or New Mexico, and advertised in Mopar Collectors Guide. I have lost contact information over the years. You might try the "C" body guys.
View attachment 1243314 View attachment 1243315 View attachment 1243316
Are you talking about the gold ones, usually on a dual quad setup? If so ive seen them on Ebay.
Put on your concourse judging hat for me. Aside from the brake MS, what else can you see that is not correct for this 62 Fury, 361/4 engine bay? View attachment 1200981View attachment 1200982View attachment 1200983
Did you get that car from somebody in California?hey.. i dont get on here as much as id like to..here are some pics of my 62 vert..318 auto..still working on it..i've replaced everything underneath..kept it torsion bar suspension but went with mostly Qa1 stuff..new upper n lower contol arms..strut rods ..torsion bars..EVERYTHING to do with steering..new 1"over springs out back with new 3.55 sure grip and axels..all new brakes with Leed disc conversion up front..double pot master and prop valve..saving for some HP right now.. then on to some seat recovering and finally a fresh paint and some re-chroming.. it looks much nicer in the pics than it really is..paint color will stay the same..it's a 55 plymouth color Pompano Peach..
View attachment 1264382 View attachment 1264383 View attachment 1264384 View attachment 1264385 View attachment 1264386
In all the times/years that I was racing my 62 at the street legals in Pomona, I only saw ONE other 62 at the track.... a convertible 62 painted peach. It wasn't racing, but it was In the pits.
Welcome Curly, from another PA resident with a 62 Fury convertible!hey.. i dont get on here as much as id like to..here are some pics of my 62 vert..318 auto..still working on it..i've replaced everything underneath..kept it torsion bar suspension but went with mostly Qa1 stuff..new upper n lower contol arms..strut rods ..torsion bars..EVERYTHING to do with steering..new 1"over springs out back with new 3.55 sure grip and axels..all new brakes with Leed disc conversion up front..double pot master and prop valve..saving for some HP right now.. then on to some seat recovering and finally a fresh paint and some re-chroming.. it looks much nicer in the pics than it really is..paint color will stay the same..it's a 55 plymouth color Pompano Peach..
That looks great on your car. Plymouth should have kept that color for '62. What part of Pa. are you from?[/QUOTE
Thanks. I'm Out on the eastern side. Town of Bath in the Allentown area. About an hour north of Philly.
It does not get any better!!
Bought a 64 Dart and emptied a 5 gallon bucket of sand and dirt out of it. Dirt but no rust !sand filling the nooks n crannies.
Thanks for this Fury! A couple of new observations I hadn’t caught. I knew the radiator was a 68’ but didn’t realize the hose routing was different or the water neck.. Any place that sells that flap under the resistor you mentioned - or a picture of it?The radiator is wrong, inlet should be top right, water neck is wrong, alternator pulley is wrong should be single, inner fender bolt all should be body painted color, missing black rubber cowl flap under the ballast resistor, valve covers did not have Golden Lion decals, left fender missing data plate. These items if only being judged against another like vehicle, other than that it's the owner's option as to what he likes. It's a nice restored Mopar anyone would be proud of.
Was this car for sale 5 or 6 years agohey.. i dont get on here as much as id like to..here are some pics of my 62 vert..318 auto..still working on it..i've replaced everything underneath..kept it torsion bar suspension but went with mostly Qa1 stuff..new upper n lower contol arms..strut rods ..torsion bars..EVERYTHING to do with steering..new 1"over springs out back with new 3.55 sure grip and axels..all new brakes with Leed disc conversion up front..double pot master and prop valve..saving for some HP right now.. then on to some seat recovering and finally a fresh paint and some re-chroming.. it looks much nicer in the pics than it really is..paint color will stay the same..it's a 55 plymouth color Pompano Peach..
You can purchase this item from Kramer Automotive Speciaties. I bought mine from there, fit perfect. http://www.kramerauto.com/proddetail.asp?prod=EIT-ST-006. BTW, Stumper, did you once own a '62 bad *** 4-dr.
