I got back from my business trip and was met by my new Edelbrock Pro-Flo 4 FI set-up!  After having used an Accel DFI system in the past I can't tell you how pleased I am at the quality of the Eddy kit, it's light years ahead of the Accel, though admittedly, Edelbrock did forget to include a temp sending unit in the kit.  No big deal, I called them, told them what happened, and they're sending me one without question or issue.
Word of advice: if you're planning on ordering one of these kits with up-sized injectors (stock are 35lb/hr and I wanted the 60lb/hr option) from Summit or Jegs you
MUST tell the sales person it is a special order that needs to ship directly from Edelbrock.  It took over a week for the Summit team to figure this out (Jeg's took even longer) and get back to me with how things had to happen, but in the end, I got my system.
Here's what I got:
Kit #35901 includes the 7" Android touch screen, which comes pre-loaded with the Pro-Flo 4 software.
The intake came fully assembled with injectors, rails, TB, and sensors in place.  I did end up switching the fuel cross-over line to the front of the fuel rails since my fuel hard-lines stop at the firewall, making for an easy, and fairly well hidden fuel line up to the rails.
Wow, what a difference to the old DFI system!  The wiring is clean, uncluttered, nicely laid out, and the size of the ECM is shockingly small:
Instead of trying to guesstimate where the sensor leads needed to be, and how long they needed to be, I chose to toss the engine in, add the heads, intake, and distributor (dual sync included with the kit), and then run the leads.
Once the engine was in and I knew I had more than enough harness length, I decided to mount the ECM inside the car, at the right end of the relay board, and run the leads through the firewall. I think it makes for a much cleaner, uncluttered look in the engine compartment.
The only problem, if you want to call it that, is getting the two primary harness connectors through the firewall.  I wanted to keep the hole in the firewall as small as possible but the two connectors meant drilling a 2" hole, which to me would be unacceptable.
So after clearly marking everything I "de-pinned" both plugs, drilled a 1" hole in the firewall, put a grommet in place, slipped the harness through, including a couple of other harness leads for my oil and temp gauges, then re-assembled the connectors.
I've spent some time cleaning up the routing and will get some more pix tomorrow.
