JB400
69 Charger
Your hard work paid off. Looks great
right here you talk about epoxy and rivets on woing window. this is what im doing next on my rt any help appriciated.I have no idea what you’re referring to?
I had to make new outside rockers. Now i have to figure out where to locate the holes for the chrome trim.These projects progress and you never quite know how they end or what things need addressed when they get done. What happens after the first drive?
My list of 'what's left' is the rocker molding and grill/bezels. Getting close with the grill, didn't start the rockers yet.
I did get to drive about 10 miles today after the alignment. Here's my list:
- Speedo - I noticed the other day it didn't work on my 1-2 mile drive. Brought it home and messed around with the cable at the trans. Ran a drill and proved the speedo and cable both work. Hooked it all back up and today it worked. Guess it wasn't seated somewhere.
- Fuel gauge - these aftermarket sending units are garbage. There's about 10 gal in the tank and I'm on E. I crawled under the car and shorted the sending wire and it went to F. Wire and gauge work. Measure the ohms and I have 78 with 5 gal in it. Checked ground and that was good too. Guess I need to pull the sender. Ugh...
- Neg Battery Cable - more junk. I have a habit of disconnecting the ground when the car sits. This morning I grab the cable to put it on and the wire pulls out. To fix it I drilled a 1/4" hole in the bottom and got the soldering iron out. Heated it up and melted a bunch of solder in the hole.
- Brakes - after my drive they were way too tight. Had a little smoke coming off rear brakes. I'll adjust them down a little.
- Kick Down - I have that adjusted to FSM specs and I can tell I need to play with that a little too.
Other than that, this thing seems to be running pretty good.
I need the vertical measurement center hole to lipNext spacing. This is a reference post. Measuremnets are from the rear wheel well, you can see where I clipped the tape measure. I pulled the length of the rocker not moving for the tape for the total length.
from the bottom of rocker to center of hole in clip.lip of what?
Great help
Thank you very much, I appreciate the compliment.Just went thru your entire page from start to finish, couldn't quit looking, really impressive, I'm actually in awe of the work you have done. I really enjoyed the post and thank you for documenting it, I'm in the process of a 66 coronet and this has inspired me to get mine done. Beautiful work, Thanks
