So last night I was up in my loft pulling out some parts that I have to bring to Carlisle for a friend of mine, and while I was up there I started putting my hands on the parts that will be needed to start assembling the car. Two weeks ago, I sold the hood and right front fender that were on the car to a friend of mine who is starting to gather up parts to build a Daytona Charger clone for one of his customers. The hood was a solid California piece, but someone who owned the car before had stripped all the paint off the car,except for the roof and left it outside so it was covered in surface rust. I changed the trunklid quarter panels and dutch panel so that took care of the surface rust on the back of the car. I have a nice purple driver's side door from a 70 R/T that I am going to use for the car. The drivers side fender came from an f4 green car,has some minor surface rust on it,but it will clean up with some evaporust,and etch primer,before the epoxy primer is applied. I have a super clean Texas hood for the car that I already brought down from the loft and put on the car when my friend took the other hood. About three years ago there was an ad on Craigslist for some Mopar parts, and in the background in one of the pictures was a 70 Charger right front fender,so I called the guy and asked him if he would sell the fender, he said that he would, so I went and got it for this car. It has a little rust on the very bottom behind the wheel, but it is the perfect fender to convert to a Daytona fender. So all I need to find for the body is a nice clean 69/70 Charger right side door. The original doors are super solid rot wise,but have the heavy surface rust from being stripped and left out in the weather. So the only area of the car I will really have to deal with the surface rust is on the top of the cowl. I will sand it with 36 grit,then go to 80 grit,then several coats of evaporust,then a few coats of etch primer,then epoxy primer should work.if I don't like the way it cleans up,I may lightly sandblast it with black beauty before applying the evaporust. Once all the body panels are welded,aligned and the car is in epoxy primer,the sunroof assembly installation will be the next task.
