HYRDGOON
- 5:00 PM
- Apr 20, 2013
- Breslau, Ontario, Canada
Hemirunner is some kinda strange Fer Racin' Alien!!
Unbelievable skills! You are in a different dimension than most of us.. lol
Axle guys say never reverse rotation, hastens breakage. Carry on, great fab work.Ok, so tonight was supposed to be more K-frame work. As usual, my brain had other ideas so it was back to the FAB9 rear faceplate. I got the idea that rather than have my buddy plasma out a new piece, I'd just rework this one. This is where stubborn met stupid, folks. I relocated a few bolt holes and the project just kept going. I got my plasma cutter back up and running and hacked out a big section on the left side in this photo so the center section would clear in the relocated position and decided I'd weld that back in on the other side. Luckily, it all worked out.
You can see the gaping holes on the right side that had to be filled without pulling it all over as it cooled.
I used a few C-clamps for alignment and to act as heat sinks. It worked.
Here it's looking kinda rough with all the welding and grinding.
Here's the finished Faceplate from the front
So, now I'm back to square one. Ready to begin to assemble the housing. The good thing is, I have the pinion offset 1-1/4" so it matches the measurements on the drive shaft tunnel in the car. Several other upsides presented themselves in this project;
1. pinion is lower than in a dana or 8-3/4 and that really helps with clearance in the tunnel since the car will be LOW
2. the offset now counters the offset in the two caps in the center section and the caps are now centered within a 1/4" That will allow me to have both axles the same length which is a real plus so they can be reversed.
3. the housing is centered in the car which looks way better
4. the axle tubes will be the same length
Thanks for the tip! I will carry on!Axle guys say never reverse rotation, hastens breakage. Carry on, great fab work.
Doug
Mike.....you are a mad man!!!! We will have to get a yellow Duster out and cruise over to check it out when the weather breaks...
