What, she didn't put the engine on the stand too??!!
I didn't try that one !!!! LOL
Sounds like you have an awesome wife. My ex-wife of 18 years could have cared less about cars or my business and is one reason she is now my X.
Thanks Mark. I have been very fortunate and have a good wife this time. I also have an ex.................... For other reasons though. (both mine and hers) We were both too young among the many other things. You have to go through a bad experience to really appreciate the good. It also makes you MUCH wiser the second time around. This time I was much more selective and made sure we had a lot of the same interests. It really does help.
I have had this little idea lingering around for a while now. I have several 440 engines that I could easily install into this 72 SSB. None of them would require too much effort.
First I have the machine shop fresh 440 that I have posted pictures of earlier in this thread. All it needs is assembly, but I kind of want to save that one for my 73 Challenger now.
It's ready to go with all new parts and has been balanced.
These 2 engines are the ones causing the dilemma.
The first one on the left with the aluminum under drive pulleys and oil pump housing was machined and assembled many years ago by Dick Landy's machine shop way back in 1979.
Remember the "Plum Crazy" FC-7 1970 Challenger at the beginning of this thread???? This engine came out of that car. The Challenger was drag raced in Southern CA back in the late 70's and early '80s and was street legal.
The last time it was driven on the street was in 1982. The gentleman who owned the car moved to FL and started it up on occasion and kept the car garaged.
When my friend bought the car from the guy who used to drag race it the engine still ran strong. In fact when we went out for a test drive before it was purchased, it was the quickest Mopar I had ever rode in as a passenger. This was back in the early '90s. The engine has been stored since then and periodically turned over and the cylinders were protected with oil in between each time.
This engine is one I built back in the mid '80s and it was also for street / strip use in my 72 Challenger that I owned back then. This engine smoked a little when it was first started, but cleared up quick.
The "Dick Landy" engine is a 67 440 HP block. The one I drag raced back in the day is a 69 year 440, non HP block.
I put and old 383 points style distributor and a used fuel pump on it to simply plug some of the holes during storage.
This last engine is a 73 year 440 HP that was originally in my "U" code Charger SE. I will be using the brackets and water pump housing from this one on the engine I decide to use in the SSB.
I have been thinking about using the Landy engine in the SSB, because it didn't smoke at all and I still have the matching transmission and converter that went along with the combination. This engine was running with a set of 3.91gears which I also have available. I'm thinking this one will be a fun one to run around with, as long as no long highway trips are made.
All it would need was to be checked out and resealed.
What do you think????
The engine I built and raced has been in several vehicles since the 72 Challenger. I drove it last in the mid '90s when it was installed in a 3/4 ton 2 WD long bed 1985 Dodge truck !!!!!!
Yep. It was a sleeper.............
It would probably need more than just gaskets and valve stem seals. At a minimum a basic ring / bearing swap plus what ever else would show up during the tear down. I still have all of my automotive machinist tools so inspection will not be a problem.
But if I do that I might as well stick with the fresh 440 from the top picture..................... I'm thinking Dick Landy now.
