70chall440
- 1:37 AM
- Feb 11, 2018
- Yelm, Washington
Yes you should be able to see what the blade is doing with the AC off. You might need to rig up a stand alone IAT so that you can still get input from that. I had this issue with the EFI 6 pack system in my Challenger and had to adjust the blades slightly.
As to the potential vacuum leak, you might try spraying a little carb cleaner around the intake and anywhere there could be a leak, if the RPM increases thats a leak.
