Check.A derogatory comment relating to a tree living, banana eating primate......
BOB RENTON
BOB RENTON
Voltage drop 0.0 for this test? Possible? All new wiring. Hmm…going to try your second test.Not seeing a voltage drop test result on the positive side, from the battery positive post to the ign1 connection (blue wire) at the voltage regulator while under load/operating. Post #8
Ok. So for test 2 above it read 13.5. I then checked voltage at battery again and it read 15.0.The FSM clearly specifies the regulator pre-set voltages and where to measure, it's not at the battery.
This indicates a 1.5-volt voltage drop between the regulator and the battery with .5 volts as the accepted maximum total voltage drop for this run. While you can compensate for this a bit with the regulator adjustment, you still have excessive resistance in the connections through the ign1 bulkhead connector, ignition switch Molex, ignition switch, ignition switch Molex, ammeter/ammeter connections, bulkhead again, and the fusible link connections. To isolate just where, take more voltage drop measurements at these various points.Ok. So for test 2 above it read 13.5. I then checked voltage at battery again and it read 15.0.
There goes my weekend! Thanks as always!!!This indicates a 1.5-volt voltage drop between the regulator and the battery with .5 volts as the accepted maximum total voltage drop for this run. While you can compensate for this a bit with the regulator adjustment, you still have excessive resistance in the connections through the ign1 bulkhead connector, ignition switch Molex, ignition switch, ignition switch Molex, ammeter/ammeter connections, bulkhead again, and the fusible link connections. To isolate just where, take more voltage drop measurements at these various points.
Not sure I agree with that. The alternator will easily put out 15 to 16 volts, which is normal. The regulator controls the voltage, so I would think you either have defective regulator(s), or perhaps a bad ground on the regulator or elsewhere in the charging system.Thanks!!! So all that’s left is the alternator.
Thanks. That was an earlier post. Lots more progress since then, but I'll take any help I can get!Not sure I agree with that. The alternator will easily put out 15 to 16 volts, which is normal. The regulator controls the voltage, so I would think you either have defective regulator(s), or perhaps a bad ground on the regulator or elsewhere in the charging system.
So a little more digging on this other Leece-Neville electronic regulator. I found this post on C Bodies and it shows the higher output alternator and adjustable Leece-Neville Voltage regulator. Cool stuff. Not something I plan on doing, but cool to see how they solved it for police cars and other ways to solve this problem. You have to look at most of the thread to see everything.I like that a lot! They all should have the adjuster on the front. I don't know why the $14 transpo units place it on the back, which is a bit of a pain. Where did you find this red one? Ebay or a website?
It says transistor on the front of the Leece — not an engineer but I think that one is electronic.I didn't read through the thread you posted, but the ones that were adjustable from back in the day were mechanical. It is always recommended to go with an electronic voltage regulator when converting to electronic ignition.
I agree with you, I've even had digital multimeters LIE TO ME!!! Sent me on a wild goose chase replacing good alternators, finally i used a different meter and it was perfect at 14.5!Out of curiosity, HOW are you measuring the voltage? With a digital meter, such as a Fluke meter or an old ANALOG meter like a Simpson 260 or equilivant. Analog devices plus the operator's interpretation of the reading is may cause the inaccuracy and the assumed result.....rather than tfying to determine where and if a few tenths of a volt exist. There is no exact, not to exceed number, maximum a lot depends on the battery's state of charge and it's age. Just my opinion of course.
BOB RENTON
Thanks! It's all brand new wiring from M&H/Year One. It's all sorted now. Thanks again!I didn't read the whole thread, but if you are having voltage drop issues (at the voltage regulator) because of the old wiring, I would power the regulator direct from the battery through a relay that is activated by the current voltage regulator power wire.
