Hi, I have a simple question regarding AFR curve vs RPM’s. Does AFR typically read 5-7 points high (leaner) at idle than at cruise or acceleration?
If my AFR is accurate and it may not be especially at idle I am reading 22 at Idle and 14.5 under acceleration or cruise ie higher rpms.
I don’t know what normal or typical is. I am using an Innovate WBO2 sensor with the tail pipe clamp from them.
