How does the shift pattern work; is 1st under Reverse? If so, does the shifter box have to be modified?
Curious minds must know.
That looks like it only fits an A body.
Its getting balanced anyway. Wiseco pistons (9:1) are back ordered. Eta of three weeks. Got a killer deal on a set of carrillo rods. Need to get a flywheel and then it all goes to get balanced. After I figure out the pilot hole of courseThen you might need to re-balance the crank, which shouldn't be a big deal.
I have had one behind my blown 6.1 stroker for some time.
The shaft had to be trimmed the mentioned 7/8 of an inch.
Biggest issue I had was with my blow proof bellhousing
I had to trim a bit of the flange on the passenger side.
Drivers side fit nice and easy.
No issues at all.
Other that that no drama
Steve
