Bb70charger500
You can order large keg of blue def gets much cheaper when you get straight from suppliers at larger quantities!
From the BlueDEF cut sheet:It also has a shelf life and goes bad when open
That's about right, it's usually around $5.00 a gallon. I get it in bulk at the pump for $3.00. Keep track of how much DEF you use compared to diesel. If you notice that you're using more and more DEF, that means that your DPF filter is clogging and causing the vehicle to regen more often.From the BlueDEF cut sheet:
Storage temperature between 12º and 86º F are recommended to maintain optimal shelf life of up to two years.
I bought a 2½ gallon jug, so shelf life won't be an issue. Around $12 at Sam's
In the few seconds I had earlier today I did a web search for a weight distribution trailer hitch and found that forum.
May be exactly what I'm looking for in a Jeep forum. THANKS
This is what hers looks like:
I will do that if I can track it. I am almost never going to drive it, and I'm not sure if that's going to happen if I can't figure out a way to do it myself.Keep track of how much DEF you use compared to diesel. If you notice that you're using more and more DEF, that means that your DPF filter is clogging and causing the vehicle to regen more often.
Not a 4 cylinder, 3.0 litre V-6 diesel.I wouldn’t think that little 4 cylinder would use much DEF, the 6.7 in my truck only uses about 2 gallons in 6000 miles. Don’t really know if engine size has anything to do with the amount used, though.
How about this one? She's 42.
My mistake, I was thinking those eco-diesels were 4 cylinders.Not a 4 cylinder, 3.0 litre V-6 diesel.
My wife drives pretty fast, 80 on the highway to and from work, and still saw 26 MPG average.
Pretty much everything that I told him, you just gave him the educated version.Warning - wall of text coming!
Congrats on the Ecodiesel - you're going to love it, but you have to treat it like a diesel...not a gasser. They hate short hops. If you can, run it on the highway every chance you get to clear its throat. Don't have to floor it or race it, but let it run at highway speeds for 10-15 miles. Forgive me if you've had diesels before, I'm just working on the assumption it's new to you Better safe than sorry!
I have just over 80k on my '14 Grand Cherokee ecodiesel and it's been awesome. Bought it brand new. Bone-stock. Not even a K&N. No exhaust changes. No programmer. Not even a boost gauge. Just. Leave. It. Alone. Lord knows, there's plenty of other stuff you can change on a Jeep...just leave the powertrain alone. It's worth it. Working in a Chrysler service department, we see Eco's with problems...if they've been modified. Or abused. Stock units? Do just fine. Leave it alone, maintain it properly, and enjoy the muted rattle and the fuel economy.
I change the oil every 10k like they say (make sure to use the right oil!). I fill the DEF once a year (literally). I put diesel in the tank when it needs it (my Grand averages - with a lead foot and a mountain commute - 24-26mpg in town and 32 driving from MD to FL for vacations), and air in the tires when they need it....and that's it, for 80k miles. DO NOT let anyone talk you into a transmission service - THE EIGHT SPEED IS FILL-FOR-LIFE. It amazed me how many customers let Jiffy Lube or Bob's Service Station talk them into a "60k mile transmission service"...and since nobody has books on how to change the fluid in the 8HP (because it's NOT a service procedure!), their transmissions always grenaded within a month. Warranty? Nope, so sorry, you shouldn't have poked it with a stick.
I haven't had any DEF "problems" or anything like that. The problems happen when people monkey with the systems, and try to water down the fluid to save money (I spend more on washer fluid than I do on DEF...). Do what it says, when it says, and you'll be fine. I think my once a year fillup runs me...like $17. Woo. Hoo.
If it goes into regen frequently (it'll tell you - "exhaust regeneration in progress, continue driving" will pop up on the dash), get it checked. Mine goes into regen every 6 months or so. Maybe. (It will do it more frequently, the more stop-and-go driving you do). For a while it was doing it every week - I had it checked, and my EGR cooler was leaking, causing the filters to gunk up. Warranty cooler (there's a recall now, I'm waiting to see if this one fails first - no sense replacing a brand new part!), and it's just fine.
Remember - diesels are different than gassers. (Again - forgive me if you already know this) Don't drive it to the corner store if there's another car available. Run it for 15-20 minutes whenever you drive it. Stop-and-go will fill the filters faster, but highway driving will clear them back out. Not even highway...just not stop-and-go. Let it idle 5-10 seconds before you turn it off (my Grand has air suspension; I idle it until the suspension settles to "enter/exit" height, and then I turn it off). Don't baby it when you do drive it, let it breathe. And remember - this is not a 6+ liter ISB Cummins. This is NOT a "power" diesel. This, is a fuel economy, LIGHT-duty diesel. That is one of the largest causes of issues with the Eco - people got them in their Ram 1500's, thought "I got me a diesel truck!"...and over-worked it till it popped. Not. A. Cummins. I hear the Eco is a decent puller, and the tow ratings back that up...but I've never towed with mine because I DO have a Cummins in the garage. Right tool for the job. You will use more DEF the harder you are working it though.
For DEF? Find a Flying-J or similar truck stop nearby that has DEF at the pump. $2 a gallon instead of $5, and no spoilage. Like I said - I fill my Grand Cherokee once a year. There's a website...findDEF.com, I think, that lets you search by ZIP code.
Congrats again! Looks like your wife is already enjoying it with the new decals...that's awesome. Have fun with it!
The tree huggers revenge.What's DEF?
