Any Jeep folks here?
They all do it here.
It's not real popular out here, but I have gotten several
on older Jeeps or Cjs, some they just set on the hood too
while parked in Safeway parking lot
None in/or on the Gladiator/Rubicon Launch Edition (debadged) 'yet'
but it's locked all the time, that I'm away from it or Dad's drive's driving it
to the dr's etc.
Neighbors Jeep/68 CJ5 Kaiser/Willys, a few month before done
I helped & guided to rebuild/restore to how his parents had it, $16k later
except for it had 33" tires not the 31.5", soon to be changed too
adding some stainless acorn nuts to the wheels too
a lil' bling (think A12)
or JUST EXCHANGE EXPENSIVE PARTS
That Works Too !
You’ll Find out when you wheel it in a dry
Rocky River bed …..
KaaRaaCrunch..
PS
4.0 Six Banger Tip…My 2000 TJ Was loosing
Oil pressure ….it would be fine at 1500rpm &
Up , but at idle it was almost zero….???
Guess what !
The Oil Pump Was an alloy housing with cast iron gears . And For some reason it would lose tolerance….& not pump like it should.
I replaced the oil pump with a OEM Melling Cast Iron Pump & Mucho & Gusto Oil pressure !
So if…..you start having oil pressure issues check your pump !
Mopar2ya
John
It’s A Jeep Thang….
I'm getting 60 PSI at idle with my 4.6 stroker and Melling stock oil pump. (60-ish miles on the engine so far.)
New Year vacation, FL keys
First stop, St Augustine Beach
Then...southward!
Finally the sun came out and the top came off....
And when the temp came up...off went the doors!
And now that vacation is over...Maryland weather again...
Great jeep commercial on the Superbowl.
I currently have 3. A 97 Sahara 4.0, 5 speed, 3” lift and 33s. 2010 rubicon 2 door, 3.8,auto, 3” lift, and 33s. 2018 rubicon unlimited (4dr) recon edition, 3.6, 6speed, currently 100% stock. In the past I had an 87 YJ on full width axles and 35”s with a t-18 trans swap and a 258. Then I also had an 83 cj7 Laredo with a swapped in 93 4.0 efi engine that was otherwise stock. I really enjoy the jeeps.
Travis..
And for the record, I don’t get the duck thing either. The wife’s Mojave got a couple in the year we had it, they went in the console. I also don’t wave at other jeeps unless they look like off-road used jeeps. There’s just too damn many soccer mom and poser jeeps running around these days.
Travis..
Explain the peps/toys on the dash pad for me someone.
How many davek members do we have here?
:lol:
