Tori
Not finding what i'm looking for in the search, but am currently reading several posts....
Just bought this Hi-Rev ECU http://www.ebay.com/itm/MOPAR-Hi-Re...ler-340-440-318-360-383-/222590478709?vxp=mtr
and with it came some pretty stern warnings and things to check.
First to check was that the ballast resistor is working. Ignition on, take voltage reading at coil. Should be 7.0v-9.0v, i'm getting 11.74v
If i take an ohm reading across the ballast resistor i'm getting 1.4ohm Is that correct ? too high ?
I did this test with the new ECU disconnected.
FWIW, i have what i assume is a stock Mopar electronic distributor, and a stock externally regulated round coil.
