furious70
Timing and idle screws need to be adjusted at the same time at hot idle. Tweak one then the other then go back to the first, searching for the highest idle - after triple checking for leaks.
The timing comment 66Satellite47 made was about installed cam timing, not ignition timing. That’s the number of crankshaft degrees past TDC that the intake reaches max lift. If that’s 4 degrees late your vacuum won’t be as good as you might otherwise expect.
What is your 60 mph cruise vacuum? Use this as a baseline to make your power valve choice. 1/2 of the vacuum reading at cruise speed. As you drop the pedal from cruise, the power circuit opens and adds more fuel to help the transition. 1st change for drive-ability.
Good advice from all, if you want local eyes on it sometime for suggestions PM me, always cool to meet people local.
Suggestions on power valve sizing (6.5 currently)?
Your point of not using up the transfer slot(too much idle adjustment screw) to get idle speed is a real good point also. PCV???
