MoparGuy68
I've researched this to see if I'm the first person in history to mount a PS cooler vertically. Looks like its been done before by other people. One of the linked articles regarding installation of a Derale cooler on a Mopar, states you can mount it vertically or horizontally, as long as it's in a position to get good air flow. They mounted theirs vertically in the article, although it is a radiator style cooler, not the loop type.
Another guy mounted two coolers vertically on either side of the radiator, one for transmission and one for PS.
I've already got the 22" core support blocking some airflow on the side edges of the 26" radiator. Mounting the cooler horizontally up against the radiator will block even more surface area. Also to mount it that way, down low, I think I'd need to run the return hoses underneath the core support.
I'm probably going to keep it mounted as is, and see how it works out based upon what I've read regarding cooler position/orientation.
https://www.streetmusclemag.com/tec...-fluid-coolers-reduce-operating-temperatures/
https://ck5.com/forums/threads/power-steering-cooler-location.315958/
