- 5:24 PM
- Mar 10, 2010
- Hanover, Pennslyvania
Kinda goes hand and hand.Great discussion. Perhaps we should start a thread dedicated to this ??
What's the routine at the other end, after you pass through the traps?
Here's my technique from start to finish. The same every time.
No. Quite capable of smoking the tires without water or line lock.Do you need to use water? I have 13 inch wide tires for the street I rarely burn, but have destroyed many 215/70's from the junk yard.
A stock Torque-Flight does not apply the L/R band in D, only in manual low. However when the speed comes up it will shift. Again wheel speed is the key, no need for 1st.I generally start my burn out in 2nd at the track and 1st on the street. No problems with starting the burn out in 1st if you want just don't let it grab. I never complete my burn out in 1st. Also at the track I do a fairly hard smoky burn out for first pass and light burnouts after that. Also if you are doing a burn out in drive you are safe as torqueflights apply low gear band in 1st so very little danger to the sprag.
