- 7:19 PM
- Jul 1, 2015
BTW, the picture attached about the ammeter function ( zero reading ) is from Chrysler literature. Then after that it comes the various mistakes made along the years with our cars:
-lack of power alternators from factory
-added accesories to batt post
-bigger capacity batts keeping same alt ( it should be the other way around ), taking FOREVER to get recharged the batt, so, more stress to the system.
and there is one mistake what made everybody never understand the ammeter, which is being labeled as an ALTERNATOR gauge where is really a BATTERY gauge. If you get an ALTERNATOR being Discharged, get worried, because an alternator can't be discharged since is not an acumulator so it can't storage power. It sources or doesn't, but never get discharged
The panel mounter ammeter, sometimes labeled ALTERNATOR, is an instrument that measures quantitatively, the amount of energy the system is producing (charging) or consuming (discharging) by having the system's energy flow through the device. The foregoing statement above is naive and incorrect. The alternator produces power both voltage and current to supply thr vehicle's needs. If the system's rnergy requirements exceed the demand of the alternator, the balance of the energy will be supplied by the battery.
The deficiencies of the Mopar bulkhead connections is well documented, but to abandon the origional ammeter (or alternator labeled indtrument) for the sake of a voltmeter, is, in my opinion, not worthwhile to consider. Perhaps, the owner should consider up grading the wiring and the connections to and from the existing ammeter, including the connections to the actual device, to eliminate any potential connection abnormalities and corrosion that may be present.
The ongoing issues of system voltage vs system amperage measurement methods is a personal decision. Voltage measurement indicates that the system's alternator and battery are functioning and are "healthy" but NOT how much energy is being consumed or produced by the alternator and/or battery.
If the owner has added addition energy consuming devices, albeit cooling fans, auxiliary lighting or sound systems, these addition loads must be taken into account in what the alternator must supply and how much additional current must be taken into account that will pass thru the bulkhead connectors and ammeter (alternator instrument). Unless these addition loads are accounted for, a parallel, relay controlled, individually protected circuits must be considered, sourced at the heavy duty battery connection at the starter motor, not at the output stud of the alternator. Just my opinion of course.
BOB RENTON
