Ok several notes because I still can see lot of stuff is not clear.
The alt just will put out whatever load the car requires as far is able to. Your car is what sucks 30, 40 or 50 amps, so the wiring must be matched to the loads it requires, NO MATTER the alt you have. The amperes are not pushed in by the alt but sucked out by car. If the alt doesn't have the capacity, the batt will be sucked out. But still will demand same load.
The problem with stock alts is they are really poor at iddle and low speeds, which depending in your driving or city, could be the most time spends ( traffic, rain ) so it keeps sucking from batt, then you give gas, and alt has to supply per battery demand, the load lost while alt was not capable. What I said the trick on this? If your car sucks a constant 30, 40, 50 amps loads then keep the batt out of the game sucking more amps... 30 amps becomes maybe in 45, 40 amps becomes on 53, 50 amps becomes on 64 amps... these extra 15, 13, 14 amps are the one being sucked by the batt to get recharged again then this will be the load going through the ammeter as a Charge reading.
While the batt is charged, the load supplied by the alt will be JUST for the car, right on the splice between ammeter and bulkhead on black wire. It won't be running anymore to batt and ammeter won't get any load going throught, zero reading. no load it means no heat. This is the ideal status.
The batt is just like a baby! Will be sucking milk while is hungry! When is not hungry, won't suck anymore!
Sure it will be load running throught the bulkhead, SPECIALLY on black wire, not so much on red wire ( same reason, batt is full, and won't be running load to that side ) so, the bulkhead bypass will save this loads. It can be done on several ways. 72RoadrunnerGTX chosen just forgett the bulkhead path and keep exclusively the bulkhead bypass. Myself I preffer to keep the bulkhead path and get an extra one being parallel. Why? Because in that way the main splice, which is in the middle between ammeter and bulkhead, will keep being sourced from both sides, the wire between splice and ammeter, and the wire between splice and bulkhead. This means the splice is being feeded by 2 12 gauge wires. Using just one path, the one bypassing the bulkhead despising the stock one running throught the bulkhead, even if you use an 8 gauge wire, the main splice is still being feed by just 1 12 wire, the one between ammeter and splice. Sure you still will be safer to feed the batt when required with this, but IMHO you can keep doubled the sourced to the main splice keeping the stock one
72RoadrunnerGTX is using what it was done from factory on earlier cars, but on laters the bulkhead path was kept in place, adding the extra path without despite the bulkhead one. 73/74 diagrams show this.
Is true stock ammeter are designed to work. On +/-40 amp range, so it won't hold 50, 60, 90 amps, but ONCE AGAIN, the alternator will never put 90 amps, because your car will never suck 90 amps. The deal with 90, 130 amps is get the best iddle capacity ( 40, 50 amps ) to keep the batt out of the game, hence the ammeter too.
You can't speed up the charge on batt even having a 400 amps alternator! Batteries gets it own chemical process to be recharged and you can't push it up. Once again, as a baby, it will get its own speed to suck the milk! in NORMAL conditions, a discharged batt can suck maybe 30 amps for 3 or 5 minutes, but once this initial process began, it will be into 10-20 amps untill is fully charged. The more charged, the less load will be sucking and you'll see this load through the ammeter. So you will see THIS LOAD going through the ammeter on its reading, not the full 90 or 130 amps from alt
