Dodge Bros
Likely the crown on the lifters was not ground correct.
Dual spring that have a spring pressure above 300 lbs needs the inner springs pulled so it breaks in the cam more gentle. That is done so less metal is removed as the cam breaks in. I don’t know what the cam is, or springs, but if they found out it was broke in with the inner springs they probably wouldn’t warrantee it.
