73LemonTwist
This spring it has been nearly impossible to get the car to fire up. I have never had ignition problems before so this is a new experience. I have an MSD 6A ignition module and am using an MSD blaster coil.
When I put my timing light on any of my plug wires and crank the engine see no spark. When I put the timing light on the wire between the coil and the distributor cap I see lots of consistent, steady spark when I crank the engine.
I have tried various cap and rotor combinations, and I have replaced the coil. I still get no spark at the cylinders. If I get lucky and it kicks, it will start and run and once its running I have no issues restarting the car, and the timing shows a consistent and regular plug fire. Leave the car over night and I am back in the will not start mode..
Any ideas, I am at a loss...
Allan
Allan
