696pack
Yes the tire will fit with no modifications..
Although the 7 inch wide rim is acceptable,an 8 inch is best with a 4.50" backspacing.
It will be a tight fit and may rub the right side inner wheel well under load or over bumps.
The cure for that is install air shocks and raise the car until it stops rubbing-aprox 1/2inch or 40 psi in the shocks.Monroe part # MA757
I work at a tire shop and had helped other members here as well.
Hope this helps.
I have said it before and will say it again, AIR SHOCKS ARE BAD IDEA!! They are actually attempting to do the job of the rear spring by supporting the weight of the car on the shocks. You will find many old cars that were the victum of air shocks back in the day with bend and even torn top body braces where the top of the shock mounts from attempting to car this weight.
JUST SAY NO TO AIR SHOCKS. If you want to raise the rear of the car do it the RIGHT way and change the springs.
