FridayGt
Ok, I've been reading through some threads on carb selection and I want to see if I can ween some knowledge from the folks on here with more experience. I've read this thread and many others here; http://www.forbbodiesonly.com/moparforum/showthread.php?t=29056. However, I'm still left a tad curious. Maybe I can preface this with my set-up and then pose my questions.
1972 Road runner
1969 440 HiPo
Hedman Headers, to 3" all the way back through flowmaster mufflers
Edelbrock performer intake manifold
MSD Ignition and coil
Tan cap distributor
Initial timing around 14.5 dedgrees
727 Trans, highway stall at around 2300
Stock cam & heads presumably
2.73 open rear - Really trying to pinch pennies so I can pick up a 3.55 Sure Grip
It seems to love 750CFM
Ok, the reason I ask is because the carb that is on the engine now was pretty shot when I bought the engine. It was rebuilt and within weeks is giving me troubles again. The mechanic that did the engine swap for me said that I really needed a new carb, but with the unexpected cost of a new engine, I couldn't afford it. Well, he tried to rebuild, didn't get it working right. Tried one of his Holley's on it and that was worse, but he was able to get the Eddie working after that. When it was working, it was amazing, but it seems to be flooding now so I'm starting to research a new carb.
Fuel pressure is good. I was at one point pushing too much as I had a non-vented gas tank and a non-vented gas cap which apparently = bad. Lol. Vented the cap and all has been good. But lately, weeks after the succesful swap, it's been running stinking rich, literally. It's funking up the garage and house and it's fouling out plugs running so rich.
So, on to the questions I have. One, anyone had a problem like this before that can reccomend things to check? My float levels are where they should be per the manual, but apart from that, I don't know much else. Looking over it I found a few things I was curious about. The fast idler cam does precisely nothing it appears. As soon as the throttle is actuated, it just dangle there the rest of the time unless it's put back. Abnormal? Also, the metal flappy thing (technical term) that is supposed to cover the front two barrels just hangs open at all times.
Next, why do you pick the carb you picked? My plans for this car are primarily to be the once or twice a week nice weather driver to work. I will more than likely continue to drive it like I stole it at all times, but track time will be extremely limited, if at all. Any suggestions?
Oh, and I would prefer a manual choke. I'm thinking 1407 from Eddie, thoughts?
1972 Road runner
1969 440 HiPo
Tan cap distributor
