I'm gonna have to disagree with this...we had a somewhat-built street 440, dyno at the engine shop at 511hp and make 390 on the rollers, with p/s, a/c and a nothing-special 727..but back on the subject, the OPs popping and breaking up as the RPMs increase indicate, he gots a problem! It will no doubt turn a higher number if it's able to reach the peak range which it doesn't look like it is currently.maybe 350 with no power accessories and a crazy efficient trans
A little update on the ol Fumblebee. I think I may have been down 1 maybe 2 cylinders during this run.
I pulled my plugs to do a check over on the whole thing and rejet the carb. And 1 had the center electrode wiped ( but the ground strap was starting to show signs of wear too ). And 1 had the center insulator cracked and chipped. No clue how that happened. The cylinder still has good compression so it doesn't seem hurt.
The cap and rotor seem to be working well but I'm still going to swap out the dizzy with an MSD One ASAP.
But it seems to be running well I went up 6 jets secondaries, 4 on the primaries, dropped the Power Valve, and it pulled a decent time in the 1/4 12.48@110 through the lights before it got hot that was my best run.
