MoparMadman
I currently have a mild 440 in my car with 9:1 compression. This number was calculated many years ago when the motor was assembled. What I do recall is the compressed head gasket thickness was .025 and 213 heads that were milled and cc’d to 88cc’s to make the 9:1 compression with the P4529429 .030 pistons.
I’m planning on replacing the existing 213 heads with a set of TF 240 aluminum heads with a 78cc combustion chamber. How do I go about calculating my new compression with the smaller combustion chambers? Thanks
