How screwed am I? Should I pull the engine right away or just the head? I am certain I caught this right away, it couldn't have run more than 45 seconds with coolant in the oil but that's long enough for it to circulate and get in all my nice new bearings. Experience only here please is a flush enough, if so is there an additive I should look into for getting rid of glycol? Or am screwed here and need to pull the engine no matter what. I still don't know the origin of the leak if its a cracked head, head gasket, or cracked block but I'm tempted to start with the low hanging fruit and just pull both heads.
Here's the play by play:
Fresh build I've been hawking the oil pressure and coolant temp (both mechanical) gauges and she's held solid 180deg so no overheating.
Blew smoke through an intersection, not a little it was a lot (think Uncle Buck), she misfired a bit and I saw the temp gauge go erratic shut her down immediately. Towed it home and found coolant on dipstick.
The Build:
'71 440rb stock bore .030"
Edelbrock Performer RPM heads 84cc
Xtreme Energy Hi-Lift 241/247 Hydraulic Flat Tappet Cam
RPM Performer Intake Manifold
Don't remember pistons but my CR was 10.x something
Felpro 1009 Head Gasket
