LowDeck451
A big consideration and something I’m sure I don’t want or need is a super fast rate or hard on the valve train type of lobe. Street/Strip in my case means 90 min. round trip to the track. I mentioned this to Jim, he said his cam would be easy on the stock valvetrain. Can’t say I’ve heard of Brookshire cams. ThanksAt 9.7 scr with the restrictive manifolds the engine likely has enough compression and residual heat for preignition to eliminate tons of the streetable pump gas shelf cams. I agree there are some shelf cams that would work fine in here though.
That Crower cam that was posted appears to me to be a mopar specific .904” lifter cam. I assume it is symmetric like a lot of there flat tappet cams, that style cam seems to like a little wider lsa compared to one of Brookshire’s cams. I think it would work ok, I kind of like a size bigger cam and use a Brookshire cam though, a fender length for a win is still a win .
Edit: Ok, I looked up Harold Brookshire - Ultradyne, Bullet, Lunati Voodoo
