Cutting templates Fenderwell Headers
evilmopar
1:26 PM
Jonkoping, Sweden
Hi everyone!
Does anyone have a sweet cutting template for the inner fenders and fottwell? I´m installing a set of Doug´s fenderwell headers on my ´64 sport fury, wanna cut as little as possible to make it look nice and not to butched. I´m installing them on a B-block even tho Doug´s states RB/Block i guess i have to ding and make some adjustment on the tubes to make them fit. Or has enyone installed them on a B/Block early b-body?
Fenderwell headers, just cut them fenders out as per instructions and then make your close fitting panels that are removable. Why? Because it takes a lot more room to install and remove them than you might think.
I´m affraid you´re right, I´will install them now when the engine is out. The good thing with these headers is that they are splited and only 3 pipes goes thru the fender and one is going on the inside and under the frame.
