Regarding the high-performance/increased clearance engines, the "8lb they" dates at least as far back as 1962 Mother Mopar. TSB lifted from Hamtramck Historical attached for perusal.
I can only tell you what works for me......Im not a racer....i just want a reliable, stock appearing engine for an "occasional" street encounter, where sometimes, maximum effort is required. The engine is 0.030" over bore, running a Mellings HIGH VOLUME OIL PUMP, with standard spring. I use Clevite tri metal bearings (full groove upper and lower) @ 0.0025" so the rod bearings are oiled all the time and Clevite tri metal rod bearings @ 0.0025". I ise APR HARDWARE holding it together. The pistons are TRW forged 11.0:1 @ 0.005" (with full floating pins) clearance and Perfect Circle low tension rings (top moly faced). The rotating assembly is balanced. The cam is a Crane equilivant to the MOPAR 292° and 0.509" lift and Crane 1.6 ratio rocker arms. I use 7 gts. of Mobil One 10W-30 w/ a pint of ZDDP added; engine uses a windage tray. Cold oil pressure is: ~80 psi @ 2000 RPM; HOT oil pressure at 1200 RPM is ~60#; HOT oil pressure at 5000 RPM is ~ 75 psi. The lifter bores are UNBUSHED; block rocker arm oil feed hole is stock. I really don't care what anyone else does or how they build their engines.....I've built Ford (406, 427, 428, 460) and GM (350...Pontiac, Olds, Chevy) 427, 455) using the same criteria ......I'll stay with what works for me.......just my opinion of course.....tell me where the oil pressure is to be at. mine was reading from engine builders in tech magazines like Joe Sherman, David Vizard reading speed talk on and on over the years. so you can tell me what it is supposed to be. the 15 engines I built over the years for myself never blew up and I never was overly concerned or stressed out about the oil pressure.
In response to your question:What is your oil pressure hot and cold RJ?
