Mopar-Charger
I didn't swap the condenser, I have an electronic ignition. Carb hasn't changed since i had it running before the oil problem about a week ago. Haven't ran it since.
Do a check for the vacume leak by spraying a little carb cleaner around the manifold where it connects to the heads, carb flange etc. Any change in engine speed, bingo, there is your leak. If you find there is crud in the carb, is it large debri or fine rust colored silt? There is NO filter made that will filter out rust in the fuel system. It will get by anything made and plug stuff up like you can't believe. One thing that it will not get by though is a magnet. On my cars I put magnets on the filters and in the tanks. Don't you just love troubleshooting? Frustrating but rewarding when you figure it out. One other free thing you can do is have the engine running with the hood open in a dark garage or at night away from any light source. If you see any corona from the ignition system you may have identified an area of issue.
If I back the timing off, it struggles to run.. too less of timing. Prior to the new heads I ran 89 once and felt the same thing. Same timing. Went to 93 and it went away. I just can't remember now if i put 93 or 89 last time i filled up.
That being said I have two more questions. The plugs are gaped at .05
Second thing is, when i torqued my heads with the new gaskets i torqued them to 95 foot lbs (1972-76 heads). Later to find they were 77 heads which needed 105 foot lbs. Could this different have affected my head gaskets?
Also, I used the same push rods. Is there a length difference between what the two heads require?
If the knocking stops with 93 octane then that's what you'll need to use. You must have some high compression to need that. Also, head gaskets come in different thicknesses and that will make slight variations to compression ratio.
As for you torque numbers, 95 Ft/Lbs is accurate for iron heads with bolts (small block). Torque settings go up when using studs but I've never seen different specs for 77 heads. According to MyMopar.com they used the same head on a 360 from 77-86.
Your plug gap seems a little big. What type ignition are you running? Aftermarket ignition systems with high output coils like larger gaps like 50. If you're running a Mopar ignition, I'd cut it back to 35-40. I'm not convinced the plug gap has anything to do with the issues you are having.
Pushrod length and valve geometry can get very complicated. However changing from iron head to iron head, I doubt if there is an issue.
Lots of little issues can cause alot of fun and get you praticed for creative words. Did you use your old harmonic balancer? Check to see if the outer ring has moved in position to the inner hub. If its moved, your timing cannot be set. East way to check is pull all the plugs out, put in a positive stop into the #1, rotate the engine BY HAND clockwise till it hits the stop, mark the balancer to meet with 0 on the front cover, rotate it counter-clockwise till it hits again, mark it. Half way in btween those two marks is your spot. Where does yours end up?
