pat1969charger
Your cruising right along Don! Do I see more pieces on the charger in the background a well?
Don, Thats some good work there, you are becoming a great teacher in fabrication work...
Thanks Ron,
Every time I start a "fix" I have no idea how to go about it.
It usually happens as I work through it! Just keep working through the problem and eventually you will get it! some fixes take a bit longer than others!
Yes indeed Don . . . so true . . . BUT, you never stop, you never give up, and you keep tackling the "fixes" one after another ! !
Budnicks referred to "the level" you've taken apart the car - that is an understatement, But it's so cool to watch you rebuilding it one step at at time!
Keep at it Don - your masterpiece is moving along nicely ! ! Thanks for the updates . . .
I would really like to get this pic scaled up to poster size and put it up over the full sized Charger puzzle. That would be cool!Looking good Don! I think the next '69 Dodge Charger puzzle you do should look like this:
Think you earned the right to dial it down a notch or two in the puzzle department.
Thanks for that info Pat,Don, I was just looking at my new floor pan and took notice the park brake cable bracket and the bucket seat blocks are all there prewelded. I know I have seen a lot of people having to add their old ones to the amd floors. My floors are goodmark. Seems though goodmark adds a lot of little brackets that amd doesn't such as inner bracing in rockers and park brake cable bracket on rear frame rail etc. Just wanted to mention it I know your using a floor from the coronet but may help others following your thread.
I have already put the quarters on for a test fit..... But could not go further because the rear of my car is against the overhead door, which means I have to have the door open to work on the car. Seeing how it's been a nasty winter that has delayed doing that.Great work again Don, I have a feeling we'll be seeing something that resembles a Charger again in the not so distant future?
Awesome work Don!
In the future, all of the "I Want to Learn How to Weld and Fabricate" questions will be directed to your restoration thread.
Thanks showard, I am subscribed to your thread as well. That is the great thing about this forum, we all are helping each other! Would you (or anyone) have some pics showing the true orientation of these tabs?Don, you are doing a great job. I am always checking your thread and learning from your progress and using that information to rebuild my charger. Keep up the great work.
I had to fix most of my grill support tabs also. One thing that I noticed when most grill supports are removed it will almost always twist the tabs some. The correct position for the tabs is straight out or perpendicular from the end of the support. They are easily straightened, especially compared to the complicated work that you have done on fabricating the tabs.
