that turned out good.
I painted the headliner bows and headlight vacuum canister
Switches
I disassembled, cleaned and tested the switches and chrome knobs.
Here is a pic of the dimmer switch
Because the spring was binding I wanted someone to rebuild it that had more experience. I found this guy on ebay. All he does is rebuild switches so I sent it to him. Here is a link to his ebay store
https://www.ebay.com/str/devinism
Then I applied the decals to the gauge faces following the instructions from Premium Dash Decals. They were not my 1st choice but performance car graphics were out of stock and they were not sure when they would have more. It all worked out, as I am extremely happy with there decals!
I installed the odometer decals as per the instructions
I found a video that showed how to reset the odometer to zero's
This video is for a mustang, but the odometer mechanism is identical
and works perfectly for my odometer
Now you need to polish all your stainless trim, redo the seats, and hopefully your interior panels are in good shape so you can just clean them up and put them back in.
Great job! You're inspirational! How are you going to do the wood grain plates for the dash?
I had a circuit board pin that was broke, and after a lot
of researching how to fix them, I ended up getting it turned on a lathe
and running a 1-64 screw thru the back of the board to hold the pin.
In this pic you can see the pin that I replaced (on the left)
In my research I found a thread where a guy had done a similar repair and almost caught his charger on fire. Turned out that the circuit board was grounding out on the housing.
Of course this freaked me out a bit! After checking it out I found that there is a channel in the housing that is right behind the pins. This channel should clear any contact, but because I had modified the board with my pin repair
(I had the head of a tiny screw protruding on the back side) I decided to add
a little more protection so I applied some electrical insulating coating which is kinda like liquid electrical tape.
Here I assembled all of the switches and gauges back in the housing except for the clock
I got the bezels painted and "chromed" with the Molotow chrome pen.
I know it's not the best, but for what it cost to re-chrome, I'll try the pens!
So I had just had to see how it looked with the freshly painted bezel on.
I am impressed. Now to get the clock rebuilt.
A lot of interior work to do in the future. The wood grain plates are coming up.
Stay tuned
Stay tuned
$$ not a cheap car to redo, but then again its not a chevyNice job on the chrome, gotta save $ for the big ticket items!
Clock is done. I will get this thread updated soon.Are you going to rebuild the clock yourself?
I used an Argent paint pen for my AC vents. Looks ok. I don't think it's supposed to have a high chrome look like the dash.
I checked out a video on the Molotow chrome pens. I'm sure you looked up these pens too. I was curious to see if they are any better than the paint pens I have. The thing this guy Pattison concludes is that the finish is not very durable on either of the two pens he tested so just be aware that touching the "chrome" will rub it off.
Hey Paul, swing by anytime!Nice stuff Don! When can I drop mine off for you to spiff up?![]()
Like they say at one of my favorite restaurants... It's my pleasureMan just caught up on this thread and must say nice work man! Doing my 68 Runner now and thank god its solid as alot of that tedious metal work can take forever. Keep it up and thanks for taking the time to document alot of the hard stuff!
Not a body man! No I have NEVER done anything like this before!!!Are you a body man? You say you are a beginner but just wondered if you've done
work on cars before this project.
