origcharger
More photos comparing 440 source link with OEM link from a 1970 Super Bee
Hello Origchargers. Thank you very much. This clarifies in picture form how much the link differs from the original.More photos comparing 440 source link with OEM link from a 1970 Super Bee
330.full metal jacket would it be possible to see some pictures of what you did? i was thinking about cutting mine and putting a chrome moly tube to make it the correct size as my oe one also.
Thank you, but I'm not pulling the pitman arm off. I just want to remove the center link from the idler arm while on the car.I use a puller like a 27170 OEM to remove steering joints I want to reuse, a picture can be found on Summit racing website
I know, they call it a pitman arm puller but the one I have can be adjusted tighter in order to “pull” the center link or steering arms off the center linkThank you, but I'm not pulling the pitman arm off. I just want to remove the center link from the idler arm while on the car.
Gotcha. I sit corrected. LOL.I know, they call it a pitman arm puller but the one I have can be adjusted tighter in order to “pull” the center link or steering arms off the center link
Did you use an OEM link? When the link was turned to fit inside chrome-moly tube did you offset turn it to drop it a little more? What saying turn it like a crank to gain stroke and use a rod with a smaller big end.Here's a close up of the lightweight drag link with the seam weld where the factory curve drop transitions to the straight bridge section. The plug weld which was ground finished is hiding on the top section.
Yes, an OEM link original to the car.Did you use an OEM link? When the link was turned to fit inside chrome-moly tube did you offset turn it to drop it a little more? What saying turn it like a crank to gain stroke and use a rod with a smaller big end.
The drop link was rubbing the pan enough to make it leak or was it the old link before that?i installed a drop link. needed an alignment but not much of an issue at all. was rubbing hard enough on the oil pan that it was leaking.
Gotchaold link was rubbing
drop link fixed it
