Two comments:
1) The ramp curve of the cam to get .509" lift is much more aggressive than stock, so the stamped rockers are not recommended. I think the theory behind it is due to the spring pressures and forces of the valve train components caused by such an agreesive curve. I had a 288R grind solid roller cam from Comp with a .550" lift, using the "pretty gold" 1.6:1 roller rockers (so the lift was even higher), the valve train was very noisy and broke twice. (That roller rocker set-up sucked - I couldn't wait to get it out of that engine.) I pulled the big cam, went with the hydraulic flat tappet 270/270 with .486 lift and am now going back to the stock rockers (engine will be running again after I reassemble and paint).
2) I purchased Mopar Performance rockers, part #s P4529477 and P4529476, which were supposed to be the magnum rockers (thicker). I compared the thickness of the steel between some used rockers I bought via ebay (supposed to the magnums), my stock 1964 383, and the new parts, and all measured .135" +/-,005".
