BigLime
Lots of bounce on your fuel pressure gauge. Looking it up, the Sniper needs 50-60 lbs.
Looks like your needle at idle is right there bouncing on the low side. What happens when you rev. it, looking at the gauge?
I assume your regulator is right at the carb, behind the gauge?
Also, I would expect the liquid gauge to be dampening the readings a tiny bit, so you are probably well below 50 when the injectors are pulsing, even at idle.
(Just noticed that this is a few month old post. Where you able to fix it? Just curious.)
