Daves69
Any behind the pedal rod?.........is in place between clutch rod and z-bar............
If the fork spring is not strong enough to pull the play out of the linkage it will rattle.
Looks like a sweetheart of a car!Use a good spring on the fork to the bell. It holds all tight. Pulling up on the pedal with a spring just leaves all that play in the slotted holes in the linkage. I just went round and round with the car here. The modifications to the Z bar for the TTI race Headers this guy bought and the diaphram clutch had me pulling my hair out. All is well now and the customer is happy.
This was on a car that came in for a wiped cam. One thing led to another and the whole motor got rebuild. The car was a Rust bucket. I install all motors from the bottom . When going to put the K member back up we saw the frames were rotted. So it took a whole front clip and floors. Then he wanted the engine compartment painted the original color the car came.
It just came back for the clutch and 355 gears. Now he wants rear quarters and trunk floor. Money is no object to him it was His car from the 70's and he just bought it back.
View attachment 601796 View attachment 601797 View attachment 601798 View attachment 601800 View attachment 601801 View attachment 601802
The fork spring does nothing for the slop upstream of it, including z-bar and clutch rod/pedal. I think that's what I'm experiencing.It doesn't matter how many insulators you have in. If the fork spring is not strong enough to pull the play out of the linkage it will rattle.
You are correct, sir - I think. Pedal seems to be bouncing linearly as the clutch rod moves to and fro on its' slot.Seems to me the "free play" in the issue is between the bell crank and the pedal "up" travel since the over center spring is out, no?
Re: clutch fork spring...Why I hook the clutch rod spring to my bellhousing and not the Z bar. Then it takes care of all slop. (yes I know the clips not in final position)
Similar thoughts have danced through my head as well.Out of the box............
Maybe make up 2 nylon insulators to fill in the pedal rod hole excesses? I don't know if the stock retainer clips would hold them in.
Works in two directions. The over center spring not only assists in the depression of the peddle for a B&B plate spring load, but also pulls the peddle up to the stop to eliminate any flopping around............The factory over center spring on the pedal is only to assist the depression of the peddle with a Borg&Beck style pressure plate...........
You're right as far as you go - but it's quite impossible for the fork spring to do anything about tightening up the slotted clutch pedal rod to z-bar joint.The fork spring pulls the fork which pushes on the adjustment rod which pushes on the Z bar. This all keeps pressure back against the peddle which prevents the system from hanging loose and rattling. Using a lite spring on the peddle only pulls the peddle up for free play.
This can be done with a stiff fork spring which keeps all the linkage pulled back not only the peddle. The fork spring goes from the slot in the fork to the hole in the bell housing. The factory over center spring on the pedal is only to assist the depression of the peddle with a Borg&Beck style pressure plate. The fork spring is to eliminate assembly play and keep the bearing off the fingers.
You have to think with your dip stick sometimes. Been doing this for many many years.
That's actually where it goes on a 6 cylinder.'69 Dodge Coronet / Charger / Dart FSM shows spring from fork notch to a hole just above the pivot in Z bar arm. I was surprised as hell when I read that last year, as I've had it where I show it in the picture for 39 years!
The clutch pedal rods' hole in the end it attaches to the z-bar on is elongated - slotted - not a tight joint - the clutch pedal can move quite a bit in and out as a result, even with the tightest of linkage beyond it.Then as oldmanmopar concurred with me, if the fork spring is pulling the fork forward.. which pushes the fork rod tight to the Z bar pivot.. which rotates the Z bar.. which forces the clutch pedal rod tight to z bar and pedal pivots.. then nothing should be rattling.
It's you that is asking for help here, not us, and a few of us are trying to help you but you don't want to listen apparently. I've been wrenching mopar since I was 14, a mere 42 years ago and growing. Guess I'll move on and help someone else.I'm not sure where folks aren't getting that....
