Ed, forget the 'factory manual' for adjusting your clutch. You have an aftermarket clutch now so you want to follow Centerforce's instructions. As you stated, who knows what parts were used in all your linkage pieces? Here is my suggestion:
1) Pull your inspection cover and put the car on jackstands.
2) Have your wife push the peddle to the floor while you get under the car and check the clearance between the clutch disc and the pressure plate. It should be right at .060". If not, adjust the lower clutch rod to get that clearance with the peddle to the floor.
3) Have your wife let-up the clutch peddle and see where it lands. If it's not high enough for you, you need to lengthen the upper rod, even if it means removing it and welding in an extension, preferably with adjustment ability. Make sure the upper 'bump' stop is in place and the lower spring on the T/O fork is installed. Then check to make sure the T/O bearing is sitting away from the diaphragm cone (fingers) approximately .125" to .250".
Once you have it adjusted correctly and working, you can alter the engagement point higher if you wish through installing an adjustable clutch stop and re-adjusting the rods.
I can't help thinking that a mismatch in parts is causing you undue stress, which, in and of itself, is not healthy...
I don't want to get on you too much, but a thorough inspection of the linkage initially while someone worked the clutch peddle might have saved you some grief my friend.
Always glad to hear from you, my friend, and I appreciate your concern, I really do.
I spent a good amount of this afternoon under the car, investigating just what you describe and I have to make one statement right now before I go any further to everyone who has tried to help me:
I get it now. I really do get it! I apologize to anyone I offended with my loggerheadedness.
I had an epiphany of sorts while under there - things have to follow a logical progression in order for me to understand them.
Merely telling me how to do something is always, without fail, going to be followed up in my head by the "why does it work like that?" part.
That's where I was stuck and why I wasn't digging what was happening.
Allow me to ramble on some:
Bottom line on this critter is that when you're cranking on the adjuster nut on the fork rod, you aren't moving the throwout bearing or any internal clutch parts - you are moving the
linkage, which in turn raises the
pedal.
I know now what some of you were trying to tell me on this; I had to see it in action myself.
I got under the car and took a pic of where the adjuster was with the then current adjustment (halfway up pedal travel) and it looked like this:
I then got under the dash and wedged the pedal all the way up, then got back under the car...
AHA! Now I see what's happening!
The rod had pulled out of the fork hole some, giving me an idea of how much more adjusting I could get away with.
That's when the light bulb finally came on over my noggin.... and I understood.
I then spent the next three hours under the car, taking off and re-installing
correctly the snap rings on the joints, putting the washer/isolator back on the fork in the proper orientation, tightening all the bolts in the transmission mount and bellhousing, etc.
I then cranked on the adjuster nut some more to this point:
That raised the pedal up some from where it was, but not all the way up. Since I like it to release/engage about 2/3 of the way up, I was good with this.
Further, since all my fixing what Mr. Goodwrench had done had snugged things up in the linkage a bunch, the annoying pedal rattle also disappeared.
I was so pleased with all this that I stopped right there and went to address the shifter/transmission issue - yes, despite my giving the mechanic the actual Hurst instruction sheet and showing him how to install the shifter, he botched the 1-2 rod adjustment anyways, which I've since worked on as well.
Hell, the main shifter body bolt was even loose....sheesh.
Results are the clutch operates where I like it and the pedal rests about 2/3 of the way up.
I'm good with that. No , I didn't wind up installing a makeshift spring under the dash to pull the pedal the rest of the way up.
I might do that one day after my new stop pad arrives from Brewer's , but I doubt it.
Clutch feels good, shifter feels good, car is back to normal running-wise as well.
It was good enough news to offset the phone call from the docs, in fact. Reckon the middle of the month, the next round of tests and nuclear scan this and iodine that begin, all leading to more hacking on me or whatever. I don't care about it all that much, to be honest. Not my first rodeo...
Again, my apologies to anyone offended by my questioning and discussing this to death.
I get it now. I really do.
Oh, a little bonus for the car after I was done today:
